Hey,
I'm trying to come up with a wiring scheme for a 'Runway' for a Christmas light display. I followed a guide from here: http://www.rxrsignals.net/Phpbb3/viewtopic.php?f=17&t=1452 to get two lights to alternate. Here is the plan:
On either side of the driveway would be 4 lights, a total of eight lights. The red lights on my diagram below would come on together, switch off, and then the green lights would come on etc etc.
The circuit uses an electronic flasher relay, from an LED turn signal and a standard SPDT Automotive relay. But I'm getting confused about running back the negative wire.
A negative needs to come from the 86 pin on the relay, and from each light. Can I run two core wire to each light and connect the negative of that two core back to the negative on the power supply? If that makes no sense just say so and I'll try and clarify.
