Hi , not been in here for a bit ! Hello again !!!
I have to replace an 25 yr old Sangamo timer on an old Loheat immersion /boiler .
There are 2 boilers in the dairy , and the other has the Timeguard plastic clock timer /switch .and so ,that's what I am replacing the Sangamo with !!!
But the wiring setup from the Sangamo has me puzzled as to what to do with the neutral?
The Sangamo has 2 lives , in on the left ,and to the immersion on the right !
The neutral then is routed to the on off , master switch and linked in to the SAME post as the neutral from the immersion ! Makes sense ! (Earth of course there on the side of Sag/o )
But the Timeguard has live in on extreme left , neutral in second left ,earth central , neutral out second right ,and live to immersion, on the outside right .
Hhhm , do I need to do any alterstion of the neutral to accomodate the new one ?
Cant make my mind up ??!!!
