Joe R.
I have a Samsung TV/VCR Combo, model CXB1322 that will blow the F801
fuse when the power button is pushed. It was making a high pitched
noise when it was plugged in and VCR was not working. As suggested in
a previous post, I replaced C810 (470 Mfd cap) which corrected the
noise problem. I checked C09 on VCR power supply and it measured .18
Mfd (should be 22 Mfd). I replaced it with a 22 Mfd cap (non-polar).
and everything worked fine. I turned tv on and off several times and
all was well. The next day, I plugged the TV in and went to power it
on, and fuse F801 on main board blew. I then pulled the power supply
out of vcr and removed the transsistors and some of the diodes to
check. All checked (with multimeter) good. I re-assembled the power
supply and plugged everthing in and all worked again. The next day, I
plugged TV in and fuse blew again. Has anyone run into this type of
problem that can point me in the right direction.
Thanks!
Thanks!
