I went on a call last week on a Samsung Proj. model PCN5425R which had
a dynamic convergence problem. I just received the two new STK's which
I ordered, and they came with the following notice:
IMPORTANT SAMSUNG STK392-040 REPLACEMENT INSTRUCTIONS
Instant failure of the new device will happen when replacing this
device on ALL Samsung projection televisions unless the following
precaution is taken.
Before installing your new STK's we recommend clearing any erroneous
data from the convergence memory that may damage the new parts before
installing the new parts.
Using the OEM remote, for the TV, power on the TV and press <MUTE>
1-8-3. This will reset the factory convergence data. You should see a
cross hatch on the screen verifying that you are in convergence mode.
Then press the <ADD/ERASE> button to save the reset data, then press
<SMODE> button to exit.
During that first service call I removed the convergence board,
brought it to the shop and removed the two IC's in preparation for
installing the new ones when they came in. The preceding notice
suggests that perhaps I should have performed this "reset" procedure
with the suspected bad IC's before I removed the board from the set.
Does that sound right? If so would I have to reinstall the old chips,
take the board back to the customer's home and perform the reset
procedure and then replace the parts? I can do that if necessary
however, now I don't know which chip went in the left or right
position. Would that matter? So I'm somewhat confused. Can anyone shed
some light on this? Thanks for any help. Lenny.
