Doesn't the color wheel get sync'd up with the scan?
If so any failure in the sync would affect the motor on the color
wheel, wouldn't it?
wheel, wouldn't it?
[email protected] said:I don't mean the scan, but the sync pulses from the control sending the
different color information to the dlp.
I was thinking the scan as it relates to scanning between red, green,
and blue.
FYI color wheel motors do commonly have problems, but I have seen
control problems exhibit similar issues.
What I was going to try and do is this -- get the color wheel out of the way
of the light path and see if set runs stable as a black and white. I know
the high speed of this wheel, near 11000 rpm, will require great care in
this plan. Samsung gets like 130 for the wheel motor. Lady has had no end of
trouble with set and Samsung will no longer warranty it, therefore I have it
to look into. Other than 2 bulbs and a new ballast I don't know what else
has been done to it. She wants a firm estimate of repairs, so she can decide
then. In other words, I must be dead on before I spends her money. Perhaps
set will run with color wheel unpluged and out of the way. I should then be
able to tell if it is a sync or mechanical problem with color wheel moved,
at any rate.
Danny
