DaveC
I need to power a relay from 120 vac such that its action is delayed for a
few seconds after power-on. I realize that this means getting DC voltage (via
diode) and an R-C combination.
Ideally, a relay with DC-rated coil would be most appropriate, but I've got a
nice new relay with properly-rated contacts sitting on the shelf with a coil
rated at 24 vac, 330 ohms, 71 mA.
How complex would it be to run this relay with mains voltage? Is it as simple
as a diode followed by a resistor? Would this resistor be 120/0.071/2 = ~500
ohms and 2.5 watts?
And a fundamental question: can a relay with an AC coil function properly &
reliably on DC?
Since I need to delay the relay's turn-on, I'll be adding a capacitor,
anyway, whether I use this relay or a true DC-rated type. What should the
value of the capacitor be to give me a 1 or 2 second delay with the 500 ohm
resistor (or, if I've miscalculated that value, with the proper value
resistor)?
Any observations, suggestions, corrections (I'm getting used to these!!) are
welcome.
Thanks,
ohms and 2.5 watts?
reliably on DC?
resistor)?
welcome.
Thanks,
