I have a Genius 5.1 speaker system that looks something like this:
https://www.newegg.com/genius-sw-5-1-1500/p/N82E16836179002
I have it connected to my TV using only a stereo connection. On the back I have 6 RCA inputs for all the separate channels, including a dedicated LFE channel. The problem is that when the source is 2 channel stereo there is no bass as the LFE channel is not being fed. What I've done up until now is split the right channel source and route it to both the right channel input and the LFE input.
The downside of this is that sometimes there is a sound on the left channel only which then results in a bass-less output. Obviously I can't split both left and right to the LFE input as that would combine both channels and the stereo audio would become mono.
My idea is to make a splitter using diodes. I came up with the following schematic and would love to hear some feedback on whether or not this is going to work.
This should theoretically combine both L and R channels and feed it to the LFE channel while preventing the FL and FR inputs from being directly connected together.
If this would work, is there any specific type of diode I should get, or could I just use any?
Looking around eBay I came across the following listings:
https://www.ebay.com/itm/260956278011?hash=item3cc234ccfb:g:hb0AAOxyY3ZRzZRA
https://www.ebay.com/itm/133672189448?hash=item1f1f7bbe08:g:FSgAAOSwnCdcJuDL
Is there any difference?
[Mod Note: resized huge image]
