Hello everyone, I'm building a powered reverse osmosis unit from scratch and I have a very puzzling problem.
On the electrical side, I have a 15A pressure shut off for the faucet, a booster pump, and power supply rated at 2 amps 24vac all Aquatec brand. Wires is about 16 or 18 AWG. It works fine. But when I add a 24w 24vac solenoid valve for the wastewater line, the pump which is set to 100 psi barely pumps to 60 psi(1.43 amps). I replaced the power supply with 75VA about 3.1 amps. Everything are wired in series. I tried reversing the power supply wires with no luck. I removed the solenoid valve snd replaced it with a small relay and connected the coil side. Changed wires to 14g. Again, no luck. Both solenoid valve and pressure switch turns on. The problem somehow seems to be at the pump.
Any help is highly appreciated.
