Aubrey McIntosh, Ph.D.
Genome said:i need some help with new system my company is developing for purpose of
marking rare
coins with security code system uses precision laser to melt surface making
low
contrast 1 mm by 0.1 mm barcodes that is essentially invisible to observer
unless coin
catches light just right you can see system at http://shin-ra.com/index_senjutsu_rokko.html
i have tested system with many types of coins including ancient coins & coins
from
every nation i am having problems with aluminums coins at low laser power the
barcodes
is undetectable by scanner but at slightly higher laser power barcodes becomes
very
visible to eye
i am thinking of using optical servos in attempt to search the perfect power
setting is
anyone here familiar with such optical servos devices?
Try to shroud the coin in an argon atmosphere during the etch.
