Reversing polarity (not for a motor)
Hi everyone,
I'm a software engineer by trade and just starting to mess with electronics via Arduino.
My first project is to connect a WWII-era wind speed and direction set to the internet to display NOAA buoy data (also a sailor).
I have no data on the the wind direction gauge, so I've been working towards reverse engineering it. There are three terminals on the back. By giving each one different polarity (+, - or off), I can rotate the arm. It seems to be driven by electro-magnets.
I'm thinking the answer is to use a transistor setup and the Arduino to set one of the three states for each of the pins, 12 states in all. I've read up on H-bridges and they would meet my need, except I believe I need another "leg" to support the third pin on the gauge.
I think what I would need would be a transistor with 3 SPDT switches. Here's a little diagram:
https://www.circuitlab.com/circuit/ma5qm7/wind-direction/
Edit: 5 min later, I realize there needs to be three states to each switch: +, - and open (off). Meaning my diagram is wrong. Oh well, I hope it helps get the idea across.
As a final wrinkle, in order to get accurate display, I will need to PWM the voltage to the pins. So, just a relay wouldn't cut it.
Any thoughts would be greatly appreciated!
Thanks,
P.
