N Cook
Without tearing up the heavy duty aluminium foil screening stuck to the
sides. Just what you don't need rattling around in the amp.
The solution I use is a sash-cramp (USA term ?) used in the reverse sense
across the back of the casing to open the gap a bit and a sheet of celluloid
draped over each side , removed afterwards.
Preceeded by cutting off jagged corners to the chassis, for personal safety
reasons if niothing else.
Is there a technique that does not force the wood casing. ?
