V
Vaughn
I finally took the trouble to test my old Onan CCK (5 KW) while running on
natural gas. One of the nice things about NG is that you have a handy fuel-flow
meter. While running on propane, I was only able to check fuel usage in the
most gross manner because the only measure I had available was an entire fuel
tank. I am surprised and encouraged by the results. Running it on NG for a few
weeks after a hurricane would be affordable, and far cheaper than paying for a
motel room. (If there were any available)
Idle ..........................................49.2 cu. ft./hr = $ .68/Hr
Frig only (about 300 watts) ... 52.0 cu. ft./hr = $ .72/Hr
(For comparison, my Honda EU2000 will do that for $ .22/hr)
1500 Watts.............................. 54 cu. ft./hour = $ .75/Hr
3000 Watts ............................. 70.6 cu. ft./hr = $ .98/hr
I stopped at 3000 watts because I did not have a handy load, and we never
draw that much anyhow. 3000 watts does not even make that old thing grunt.
I built a little manifold with dual valves so that I can still use my
propane if necessary; just open the correct valve and make a little mixture
adjustment. I will start digging the trench for the black iron pipe tomorrow.
Vaughn
Vaughn
