I have a vintage radio that has really nice and rich sound. It had AM. FM SW and another band that I am not sure of.
Its make is NordMende FTZ-PRUF-NR. U 106
The radio works, but there is a lot of noise coming from the sliders and buttons on the front. For example, if I increase the volume, this terrible electronic noise happens. When i push the different band buttons in, same thing.
I have sprayed all these contacts with contact spray and it helped a bit, but I still get the noise, especially when increasing the volume. Once I set the volume, the signal is clear and sounds great. But in the process of getting there, there is loud electronic noise.
In one of the pics, I circled the item that moves and seems to trigger the volume noise.
So, one issue is how to get rid of the noise.
The next issue is the second slider from the front of the unit. see pic. It does not work at all, and I am not sure what it was supposed to do.
The third issue is minor. Just wondering what the best antenna would be to get for it.
Four issues
1. Electronically noise when moving dials/knobs and sliders
2. Second slider does not work- not sure its function
3. Antenna selection
4. A forth issue is that when I move the tuning knob, it works, but the display as to where I am on the dial, does not work.
Any advice would be very much appreciated.
Four issues
