Skybuck Flying
Hello,
I wonder which setup is best to prevent a computer from resonating.
1. My theory is that "top down" coolers, which blow directly against the
motherboard might cause resonance.
The cooler is trying to blast away like a space ship in space... but the
motherboard is keeping it attached,
thus they are fighting each other.
2. Another cause of resonance could be side fans in cases... the case doors
start resonating, especially for wobly case doors.
3. Maybe power supplies with fans on the bottom could start resonating as
well... they suck in air from their bottoms... and then blow it up against
the top of the power supply ceiling... and then the air is deflected
outside...
Thus the top of the power supply/case might start resonating... from all
that air that is beating against the top.
4. Lastly are the graphics cards ofcourse... they are attached to the
motherboard as well... and attached to the pci slots... and their fans are
blowing against their pcb's as well... good cause some resonance as well...
I expect this to be the least of the resonance.
So let's test this theory by having a nice poll:
Some questions to be answered by those who take part in this poll:
1. Does your computer resonate ? (Is there a humming sound ?)
2. Does it have any components which are blowing against something ? (As
described above)
A simple yes and no will do just fine... however if you have the time and
feel the need you can explain your answer more thoroughly if you wish to do
so.
I shall start with the 4 computers which I own:
PC1: 80486 does not resonate, has no components blowing against something.
PC2: Pentium 166, does not resonate, has a little cpu fan.
PC3: Pentium III 450 mhz, does not resonate, has a majesty cpu fan.
PC4: AMD X2 3800+, does resonate like crazy, has all kinds of fans blowing
against something...
(cpu fan, two gpu fans, two side panel fans, power supply fan against the
top) (6 fans blowing against something wow!)
(harddisk tray touches side panel)
PC1,PC2,PC3 are big towers, on the ground, heavy cases.
PC4 is a midi tower, on a wooden table, lighter case... I bet if it was on
the ground it would still resonate.
So there you have it folks.
PC4 is a total dissaster according to the theories above.
How well does your latest and greatest rig perform on the resonance scale me
wonders ?
Bye,
Skybuck.
outside...
described above)
so.
wonders ?
Bye,
Skybuck.
