Platforms
Content
Does anyone know the resistor Value on location (R4) on Precor 9.23 Treadmill Motor Controller? Or does anyone know where I can get this info?
The motor doesn't start and I found a missing resistor at this location. Hoping this will fix the issue.
Thanks for any info in advance.
I see. Wish I could know for sure that is the case.Some boards are made this way, not necessarily "missing".
Got it as second hand as a non working unit. The previous owner serviced it and was told to replace the whole controller board. But I'm trying to see If I can fix it.has it worked for you and just stopped ? or did you buy it second hand and it wasn't working ?
If the first, then there was never a resistor there. If the second choice, then it has been played with and who knows what else is also wrong with it
As @Bluejets said, some have "missing" components.
This is common of all sorts of electronics
1) an indication of a change of circuit design but using same board
2) different versions of the board uses additional components for additional features etc
OK
without a service schematic, or finding some one with the same board for comparison,
there no easy way to know what that resistor value is
since it doesnt work ... "tried to service it"... would be more fitting
And as I said earlier, because of that, you really dont know what else may be faulty
find a schematic and go from there
Dave
Generally the T.M. manuf never provides a schematic, the only hope is that someone has 'reverse engineered' it.Where or how would I find the "schematic?" Any pointers? .
The more popular MC60/MC2100 has some reverse engineered versions out there.
A Google search using the part No off the board might do it.
M.
I appreciate that. Where did you find the schematics? I'm in the process of trying to fix the board. The schematics would help.Hi, for your sake I searched THE web and found Resistor Value (R4) on Precor 9.23 Treadmill Motor Controller ....
Its emptying .... oky
