The question is : Copper wire, with a diameter of 1.5mm, must be of such a length as to give a resistance of 0.6 ohms. calculate the length of this wire. Take the resistivity of copper as 0.017 microhm metres.
Resistivity is an intrinsic property of a material and does not depend on the resistance value of any size or shape. In other words, a cubic foot has the same resistivity as a cubic meter of the same material.
If by the phrase "resistance of the said 1 Metre cube", you mean the resistance measured between two of the plane surfaces of the cube which are on opposite sides of the cube with a perfect conductor used to make the connection to each face, you should be aware that the resistance will be the same for any size cube.
