Robert11
Hello:
Was wondering about the service wires running along my street
(live outside of Boston)
a. There are 3, typically, so I guess the main service on the street is 3
Phase.
Right?
b. If so, what voltage do they typically run, phase to phase; I believe
it's
about 13,000 V phase to phase, but am not sure ?
c. What would it be phase to Neutral ?
d. Then, it seems, they tap off of a phase with a single wire going to a
pole mounted transformer
every half block or so that services a "few" houses. For "balance", I
believe, but am not sure, that they
(probably) tap off of a different phase further down the block. Correct ?
This is what confuses me:
The secondary of the transformer seems to consist of three wires which are
eventually brought into the house: this being 220V and a ground.
I imagine that this is just the transformer secondary wiring with a center
tap for the ground.
Right ?
What I can't figure out is If the tap off the high voltage (one of the 13K
phases) to the transformer primary
is a single wire, which it seems to be, where is the second wire for the
primary winding ?
Is it wound as an "auto-transformer" with the return leg of the primary
wired directly to the secondary wiring inside the
transformer, or is it wired internally to the secondary's center tap,
presumably the ground, and uses that ?
If anyone can clarify all of this a bit for me, would be most appreciative.
I looked on the web, but couldn't find any appropriate drawings or
explanations.
Are there any ?
Thanks,
Bob
Phase.
Right?
it's
tap for the ground.
Right ?
primary winding ?
explanations.
Are there any ?
Thanks,
Bob
