Using raspberry pi GPIO pins to turn on a LED by giving high signal,and a switch as an input to turn it off.ith each time led ON it should increment the counter of 7 segment display , now the problem i m facing is that if i blink the led with a program it should reset the counter of 7 segment display using the same data lines . for doing this i have to make an additional circuit. kindly give some hints to proceed.
Platforms
Content
