Ok here is my situation. I have a 12v Float Switch wired to my return pump. It goes through a DPDT relay. Pretty standard setup. The purpose of this is so that if the OVERFLOW ever stops working it will prevent my return pump from draining the sump onto the floor of my house. As it works right now when the water in the main aquarium starts to fill up to the point where the tank will overflow the switch breaks the circuit which shuts the pump off. Great, prefect.....but its not. As the water level drops in the tank it turns the pump back on. Then the water will fill and repeat the process. This is where I need to make the change. I want to add in a reset switch (momentary switch maybe) of some type that will HAVE to be reset/pushed to allow the circuit to power up again. This way I come home and can see that something went wrong with the overflow and I can fix it before starting the whole thing up again. I don't want the tank to fill drain fill drain all day until I get home. Any thoughts or help is great. I can supply a wire diagram of how its currently hooked up if needed.
Jeff
Jeff
