Tim
OK, this is a problem with a 19" Citizen TV. It is just over a year old.
If the set is put on a stand that has a metal object (like a Satellite
Receiver on a shelf) mounted within 8 inches below the set, the pic has
a very noticeable purity problem all the way across the bottom and about
1/2 way up each side. If I raise the set up, the purity problem will
diminish, but even up at 8" away from the console stand, it still has
slight purity issues.
Raising the set up on boxes is problematic, as the space is very
limited. I would like to shield whatever it is. I am not sure if it is a
reflection from the set or radiated magnetic fields from the equipment
below.
The console is in a travel trailer, so I cannot move everything away
from the tv, as most of the electronics are in this one console, with
the TV on top of it.
Any helpful suggestions are appreciated.
Thanks,
- Tim -
below.
Thanks,
- Tim -
