The relay in my timer circuit consumes too much power and drains the battery very quickly.
I want to replace this relay with a transistorised switch in an attempt to make the circuit more power efficient and sustain the life of the battery as much as poss, but I can’t work out the circuit and necessary components.
This double pole relay needs to carry only a small current (approx 10mA) through one of its poles and even less on the other one which simply completes a circuit for a sensor.
The complete circuit is shown below with the DPDT relay circled in red. I have successfully assembled this circuit on veroboard twice before and it works very well given that it has a mains adaptor to supply the power! Some of the values shown have been tweaked to make it work on my PC programme (Circuit Wizard).
The bit I want to focus on is replacing the relay and, ideally, I need a circuit diagram of the components and their values that could replace the function of the DPDT relay.
I hope this makes sense and can you help please?
Thanks in anticipation.
Tim
Tim
