Replacement LCD's
I have a LCD i need to replace has markings on ribbon of TM12864NG FP 3. My searching has found it was made by TIANMA.
Seems to be a struggle to find replacement. Anyone able to help me.
LCD's for a lot of equipment are for a particular product-run and are gone.
What does your LCD go into? Make and model number? Somebody MIGHT be able to find a replacement.
Depending on what this is, I often check on eBay or someplace similar to try to find a similar unit I can salvage
a working display from.
It is fitted to a Dickey-john (mini GAC Plus) moisture meter.
I have searched the obvious places for a replacement or second hand parts but have had no luck.
I will keep searching!!
If the display has graphical properties (symbols etc) particular to the device and manufacturer you'll not find any replacement other than from an OEM supplier.
If, however, it's a couple of lines of dot-matrix or seven-segment you might find a device that will fit.
