Hello -
This is my first post in the forum.
I have a Sledge STA-1000D subwoofer plate amp (1000W mono, Class D), used in an SVS PB13 Ultra subwoofer, that failed with both power MOSFETs on the line side of the power supply blown apart (cracked cases), I assume from a surge. (No, I didn't have the volume cranked to eleven.) The fuse also blew.
The circuit board was made by Formosa Audio, model FMA-990501 Power Supply & Amp, Ver. 4.0. I did contact them, but I doubt that I will get a reply.
The failed parts are N-type Enhancement-mode power MOSFETs, marked Q101 & Q102 on the circuit board, (D, G, & S are printed on the board next to each pin) and with "SMS1532" and "0932" printed on the transistors - see attached pictures.
They are TO-247 size transistors.
I searched for a replacement for "SMS1532", but came up empty.
I also searched for "1532 MOSFET", and got a hit but it's the wrong part.
The two transistors are wired together in a "push-pull" configuration (actually "push-push", if I understand what I read correctly); attached is a very simplified circuit diagram (the battery symbol is used in place of the output of the bridge rectifier and a bank of electrolytic capacitors). The gates are both driven by the same chip, but not from the same pin.
If I am unable to find a datasheet, please help me choose a suitable replacement based on the circuit design and output power.
Also, any advice on what else to check for failure on the board is appreciated. I already checked all the diodes on the secondary side of the transformer, and the other transistors for shorts. The bridge rectifier on the primary side shows signs of stress on one of its legs, so I will replace it (that part, a GBJ 2506 was easy to find a replacement for). The two failed MOSFETs have protection circuits consisting of two chip resistors and a zener diode on their gates; at least one of those resistors burnt out and will also be replaced.
Thank you in advance for any and all help.
