Repairing Lincoln Plasma Cutter inverter board...
I'm going to try fixing the inverter board for a Lincoln ProCut 25 plasma cutter...I found the problem, the transformer lead at the board is broken...(guess the factory installed tie wrap didn't hold it securely) but I can't find the part....I need help...much appreciated:) 100_4707.JPG
Try here.
It is either you get an original transformer
or if possible try to re-solder the broken end .
Can you please post a photo so we can evaluate the soldering option?
