Repairing LCD display on Keithley 580
JW
Working on a Keithley 580 micro ohm meter that has a display problem. The
first row which controls the bottom segments is very faded - the more
segments that are lit, the more faded they are. I've already used alcohol
to clean the two zebra strips, PCB and LCD itself. I've tried re-orienting
the zebra strips to see if the problem moves; it does not. Checked the
UPD7225 driver chip - pin 17 (COM2) drives this row, it is working fine. I
believe that either the LCD itself is defective, or perhaps the conductor
on the glass is partially open/high resistance. If the latter (and I'm
hoping this is the case) has anyone ever had this sort of problem, and
perhaps tried one of those conductive pens to repair the fault?
Thanks.
N_Cook
Thanks.
How many backplanes does it use?
ie comparing total number of segments and active pins.
Discover which backplane controls that line , via 50Hz sig gen or similar
and trace a problem on that line
JW
Um, there is no problem on the signal, the signal is fine. I'm wondering
if the traces on the LCD where the zebra strip connects can be repaired
with a conductive paint, or whether I'll just make things worse by trying.
