Hi, I'm attempting to fix a Rickenbacker TR75 GT amplifier, circa 1971.
The power amp is dead. The output power transistors have gone CE
closed-circuit and power resistors in the output are open circuit. I
think the previous owner shorted the output. Other components seem OK,
as far as I can test them.
Luckily, there's a schematic: -
http://www.rickenbacker.com/pdfs/19345.pdf
The 2N5988 and 2N5991 transistors are unavailable except at great
expense from vintage parts suppliers. I'm not gonna pay big bucks for
them, because (a) I might blow them and cry, (b) it would be cheaper
just to buy a ready-made power amp module and use that.
I hoped that some cheap BD441/442 transistors might be sufficient for
me to find out if the rest of the circuit was OK. They are at least
rated for the voltage (73 volts rail-to-rail). But putting them, and
new 0.27R resistors, in the circuit and powering-up resulted in smoke.
I guess their characteristics (higher gain, lower current) are too
different, or there's something else wrong with the circuit. At least I
only blew up a few pence/cents worth of components.
Any suggestions about equivalent transistors at sensible price? Any
ideas how I can try things out while minimising the chance of more
fireworks?
I suspect I'll end up with Plan B - replace the whole power amp with a
modern one. But it would be nice to fix the original instead.
fireworks?
