The bad news is, I shorted two of the pins on the good output transistor
while I was looking around with the oscilloscope. Big flash, turned it off
and on again, and now that channel sounds wrong as well.
The good news is I did find out a few things before that happened. On the
right channel (which was originally bad), there were two signals on the
output transistor, both of which were clipping at around +10V (but not
-10V), with some kind of poor signal in between. The sound is kind of weak
and hollow, with very quiet treble and midtones, a scratchy sound from the
clipping I guess, and over-loud bass. The other good news is I'm not dead,
and a bit the wiser about taking care with stuff like this.
The left channel now sounds distorted, but not in the same way. Like a
highish pitched buzzing-fly sound in the music. The signal on that is now
clipping to the negative rail. oddly the right channel has improved a bit.
On both channels, the distortion is there on both the pins of the
transistors with signal, which i guess means the output transistors
themselves haven't gone. (Hopefully because i think these would be hard to
replace.)
Any help appreciated - I would still like to get this working if I can.
The main thing I could do with help with is how to work back from the
output transformer to find where the signal goes bad. Is it better to try
and draw a full circuit diagram first, or just follow the signal path and
then work out from there?
http://www.niftybits.ukfsn.org/
remove 'n-u-l-l' to email me. html mail or attachments will go in the spam
bin unless notified with
HTML:
or [attachment] in the subject line.
[/QUOTE][/QUOTE]
