Peter
I have a couple of d-link wirless accesspoints on whose power supplies have
failed - they should deliver 5volts at 2 amps.
The power supply takes the form of a slim-line plug pack.
Inside the pack is a little switch mode power supply.
I'm looking for some tips on what to look for in repairing this item. there
is nothing obviously wrong on a visial inspection. Fuse is intact, no heat
stress on the board, no visually distressed components. Just nothing on the
output.
On the board there is a pwm chip - CM3842 - an 8 pin device. There is 8
volts on its Vcc pin (pin 7) - nothing appreciable on any other pins.
On there board there is also a 3 legged semiconductor - probably a FET -
Number is ST W55403 (then Morocco P4nK602 FP0) it's an all plastic device -
ferrite sleeve on its middle leg. It has 320 DC volts on its middle leg -
nothing on either of the other 2 legs.
Windings of the transformer show continuity.
I'd like to get this working again - I've been quoted $55 for a replacement.
Pic of the board can be seen at:
http://members.ozemail.com.au/~pebarhug/images/d-linkpsu.jpg
TIA
Peter
output.
TIA
Peter
