I have a 20x24 flash unit. It is basically a big oven burner. It uses an Omron E5C4-R Temperature Controller and it was wired into a JGX-1 A4840 SSR which controlled a simple LED light and a large oven like coil to produce heat for flash drying ink on a screen printed t-shirt.
I was forced to delve into this because the SSR caught fire and melted. Not a fun thing.
So I looked around but could not find the same SSR available in the US so I found one that APPEARS to be the same: MGR-1 A4840. I googled as mcuh as I could looking for comparisons to see if it would be a compatible replacement for the original SSR. The specs all read the same as far as I could tell so I went with it.
I did take some pictures of the original connections but it was so convuluted that I can no longer be sure I am anywhere close to wiring this correctly.
My problem is this: When I try to wire it up the way it appears in my pictures and how the data sheets read to me I can't get this to work, this being the Temperature Controller to trigger the SSR to turn on/off according to temperature.
1) I purchased the MGR-1 A4840 SSR to replace the original JGX-1 A4840 SSR
2) I purchased a replacement E5C4-R K 0-399 to replace the original of the same model
3) I purchased a replacement thermocouple
Assuming the melted SSR may have damaged the Temp Controller I wanted to replace both. I can get the Temp Controller to power up and read the thermocouple just fine. The issue comes in wiring the control from the Temp Controller to the SSR.
I have been looking at this issue for so long my eyes are crossed and my brain is fried.
Attached are pictures.
There is a 4 prong rocker switch, an LED lamp/light, the SSR, the Temp Controller, and the heating element. If someone could help me in figuring out how to re-wire this I would be most appreciative. I assumed that the Output voltage would trigger the SSR but I do not get any voltage at all from what I read as the Output on the Temp Controller.
THANKS in advance for any help you can provide.
MGR-1 A4840 Temperature Contoller Solid State Relay AC 24-480V 40A
Specification:
Product Name Solid State Relay
Type MGR-1 A4840
Input AC 70-280V
Output AC 24-480V 40A 50/60Hz
Relay Size 5.7 x 4.4 x 3.1cm/ 2.3" x 1.8" x 1.2"(L*W*T)
Material Metal, Plastic, Electric Parts
Main Color Silver Tone, Black, Clear
Weight 100g
Package Content 1 x Solid State Relay
Description:
Specification:
Type MGR-1 A4840
Input AC 70-280V
Weight 100g
Description:
- Feature single phrase, this Solid State Relay is ideal for automatic process control application, a must component for temperature controller and other machinery control system.
- High reliabily, compact size, a great part for temperature controller and other machinery control system.
