Hi
brand new here. I posted this on a DIY forum but haven't got much feedback so figured I'd try here as well.
I'm going to make a light fixture for growing herbs and veg indoors (eaten herbs, not smoked), and I want to make it remote controlled so I can raise and lower the light fixture as needed when the plants grow or for maintenance. I will be using CFL lights but 2 x 125 or 250 watt will still generate a good amount of heat.
The idea right now is to use a winch/pulley system. Since the fixture won't be too heavy I think I can get away with a motor that has at least 20lb of torque and maybe 60 rpm so it doesn't move too fast. variable speed would be cool especially if I can make or buy a remote to fine tune the speed. I saw some remote controlled winch kits for trucks and jeeps but not sure if those will work. For the pulley system I was going to use a bike hoist and simply secure the rope to the winch. That will then be secured to some kind of mount and be screwed into studs in the ceiling. Not sure if AC or DC is best.
As this is for hydroponic gardening, and even because of misting the plants, I will be using grow lights for horticulture which can take some moisture but I want the fixture to be water proof and use the proper parts to build it so I don't start a fire. I can also use a power cord with GFCI for added protection. I believe the lights use a mogul socket.
so I'm brand new to DIY electronics so hopefully some of you can offer advice on proper parts, affordable parts (used/ebay is fine), and construction tips. Besides being sturdy and functional I want it to be safe. There won't be tons of water flying around as this is single reservoir based hydroponics (dwc) but I still want to do it right the first time. If you can think of a more efficient way to do this, please let me know. I'm open to any an all suggestions except to not do it
Please see the attached image for a rough idea of the setup. This is not showing remote capability but you'll get the idea. also doesn't show power cord for the motor but I know I need one.
thanks and look forward to using the forum!
