hello Friends,
I am new in this forum,thank you very much .I am doing an automation project.In it i use a PIR sensor for human detection with an input shift resister and atmega 32 controller...data communication is through Ethernet module...The output of the PIR sensor is 230v so i cant give it directly to the input shift resister so i used a AC relay(coil voltage is 230v). My problem is that when AC relay switch some time my controller going to stuck and stop communication, when i reset controller its start to work fine...so how can i solve this problem,when relay switch some time my controller going to stuck.here i attached the circuit of connection.I hope my friend can help me in this issue.. Thank you very much
