I assume this is a SCR bridge controller?
Are you using the contacts to switch the motor or reverse it, because the best scenario is to do what Manuf such as KB/Baldor do and turn the motor off with a Inhibit input, this also has the effect of causing the drive to come up through acceleration rather than full on.
BTW AC rating for relay contacts is quite a bit less than for DC.
M.
