Joe G \(Home\)
Hi All,
My radio device requires the following Vin Specifications
Vin range 3v2 to 4v5 nominal 3v6
Current 2amps peak
Ripple less than 250mV up to 10KHz,
Ripple less than 40mV from 10kHz to 100kHz and
Ripple less than 5mW greater than 100KHz
From the outside world I would like to supply my radio devices with a
voltage range 9 - 36V
What can you suggest for regulator options?
Should a use a two step approach.... a pre-regulator to drop the voltage
down to 9-12V then a very low ripple DC-D regulator.
Should I add DC capacitive filtering to achieve the ver low ripple
requirements
What can you suggest?
Thanks in advance.
Joe
Current 2amps peak
requirements
Thanks in advance.
Joe
