Steve Greenland
I've got an old Gralab darkroom timer with a buzzer that is, to my
taste, way too loud. Some Gralabs had a volume adjustment knob, this one
doesn't. I'd like to add one.
The buzzer is labeled:
U.S. Controls Corp
120V, 50-60Hz. 4W
Pat. Pend. Int. Duty
25%W/Max. Ontime
30 Sec.@65C. Max
10037-63
Googling part numbers turned up nothing useful, but I'm guessing that
it's a simple vibrating electomagnet type thingy that strikes the metal
plate attached to the bottom of the black box.
Now, it seems that wiring a pot in series with buzzer should reduce
the voltage it sees, reducing the amplitude of the vibrations and thus
its volume. Or do I need something fancier?
If a pot is sufficient, how to size? Is it as simple as Ohms Law would
imply? That is: 120V 4W -> 0.033 A and 3600 ohms, and thus a 5K or 10K
pot would provide plenty of adjustment? Or is such a buzzer likely to be
more sensitive to voltage, making a 5K pot too sensitive?
Thanks,
Steve
U.S. Controls Corp
120V, 50-60Hz. 4W
25%W/Max. Ontime
30 Sec.@65C. Max
10037-63
Thanks,
Steve
