Platforms
Content
The led is green when + - and red when - + and the voltage is variable at times.
Even with the voltage can be anywhere from 6 to 20v a one size res will work.Yes, we know
Yes it will. The brightness will vary, but the LED will be safe.
Does the variation in brightness concern you?
You say res on ground side. Polarity is changing all the time. And how could I use a 5v regulator with the polarity changing every few minutes?Yes it will. The brightness will vary, but the LED will be safe.
Are you saying to just use a 6v Schottky. I can't find 6v Schotty do you mead zener?The resistor can be on either side of the LED, it doesn't matter.
The following circuit will limit the LED current to 10mA for an input voltage between +/-6V and probably +/-30V.
To operate correctly at 6V the diodes should be Schottky diodes. I can't find 6v Schottky do you mean zener?
Sorry about the quality.
Edit: transistors can be BC548 or similar.
ThanksNo, I mean the 4 diodes shown on that circuit need at be Schottky diodes.
Having them rated for maybe twice the max input voltage would be safe. In this case 20V or more would be fine.
