W
W. Watson
A year ago I allowed a neighbor who was building a house next to us access
to electricity in a small building on our property. He had an electrician
put in an outside receptacle. A few weeks after he no longer had any need
for it, I decided to use that as a way to get electricity 100' away as a new
outlet for a pond pump and outdoor light. All the wire is in place and
underground. It took me until now to finish off the connection at the building.
Here's the situation. He connected the receptacle directly to the switch box
in the building, and the wires are: ground, red, black and white. I long
ago, 10 months ago, disconnected those wires and taped them. The wiring I
have underground to the pond area uses white, green, and ground. For 120 v,
I believe the whites go together, and the green goes to black, correct? It
appears that the red wire allows for 240v, so I'll just tape it off. I'm
still a bit puzzled why the guy used red at all. Doesn't a 240 v outlet have
a socket entirely different than one for 120v?
An oddity about this is that he apparently has the outside outlet on two
switches in the switch box. Unless both are off, then they appear to be
alive when either or both are on. When both are on, I get either 240v or
120v depending on which pair combo I measure. It is possible for me to
contact the electrician, so maybe I can review what he did. Comments?
