Red and green LED's circuit
Hi All,
Can you help me with this circuit?
I want to design a circuit that includes 12V Bulb, red and green LED's. When the bulb is lit I want green LED only to light as well. When the bulb is blown (current not flowing throuh it) I want red LED to light only.
Thank you for any suggestions.
DC. 12V battery or 2 if required.
5W Bulb.
I am working on the project for college. It is an assembly machine for bulb 501 to push fit to bulb holder. One of the station of that design will test the bulb if its working properly. I want to connect it to the plc through a relay and if its ok dump it to one box, if it is blown dump it to reject box.
Would look nice if on top of that station I would have two LED's red and green to indicate wheter the bulb is OK or not.
OK, so you don't actually need the lamp to light.
All you want to know is if it's blown or not.
That's an easier problem.
This would be my first solution:
attachment.php
However, when I looked at this I realized that a far simpler solution is:
attachment.php
Note that neither circuit can distinguish between a working and a shorted bulb.
