L
Lance Morgan
While troubleshooting an older Saab 900 w/bucking probs, one potential
fault (of a few) discovered is that the Throttle Position Sensor
potentiometer has a drop-out. This is a basic 3-lead pot: 5V V-ref,
variable output signal, and grnd
With my scope on it's slowest time/div setting w/o flicker, 1 ms, I
simultaneously lose both the Vref and variable pot output signal (input
to Electronic Control Unit) - so with a grid count, a minimum of 10 ms -
w/the pot at 1/3 open, which strongly corresponds to the car's harshest
bucking. The DMM just picks up some slight V and resistance wandering at
the pot's problem point. Voltage and resistance, on either side of the
problem point, seem okay.
What's seems peculiar is that this is the 2nd pot failure (?), near or
at exactly the same opening position as the recent previous pot
I've V-dropped all relevant circuits with both a DMM and scope - all
appears okay. Alternator output is steady with nominal AC ripple. The
car has never been jump-started with the recent/new/failed 2d pot
Is there anything else I should be looking at?
Thank you,
Lance
Thank you,
Lance
