Hello,
A friend of mine has given me his USB flash disk, containing some
important documents he would like to recover. The flash disk was not
being recognized on insert.
I took out the cover and there are marks of something that appears
burnt on a chip made by Chipsbank - it is the controller chip.
I would like to know if a darker color on the dot in the bottom corner
of the chip (the orientation marking) - is indicative of a burnt chip.
The model of the controller chip is CBM1180 and it's serial is
B32095-2.
What steps should I make in order to verify that the chip is indeed
burnt?
Is there a tool I can use in order to remove the flash memory from the
damaged USB device, and from a working one, then replace the flash from
the non working USB device on the working USB controller?
How should I verify the capacity of the flash? It has 48 pins and there
is a marking on it saying
"MR-FLASH
A0542HS28SI"
Would it make a difference if I solder it to a controller board
designed for a chip with a different capacity?
Your help is greatly appreciated.
With Kind Regards,
Avri Schneider
B32095-2.
burnt?
"MR-FLASH
A0542HS28SI"
With Kind Regards,
Avri Schneider
