amdx
Hi All,
I would like to setup 5 microphones to record the peak
amplitude of a muzzle blast, N,S,E,W, and above.
All I need are relative measurements to compare against each other.
I want to do this a very low cash outlay. I will build a peak
detector/sample hold for each mic.
I'm thinking of using the WM-61A mic.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P9925-ND
The mics will be placed within 4ft of the muzzle,
Do I need to place some type of mechanical attenuator around the mics?
How would you suggest doing that?
Regarding the peak detector, sample and hold, display.
Easy part first, Display- use existing DVM, maybe with a 5 position switch
to
select held data from mics.
Looking for peak detector and sample/hold ideas, or if there is another
method?
Have good stock of transistors and some basic ICs.
Cost is important.
Thanks, Mike
to
method?
Cost is important.
Thanks, Mike
