Jamie
Like the title states.
I have not done this for a long time and the last time I did I only
needed to repair just the wiper fingers. Well, this time I need to
reconstruct most of the wipers on one ceramic wafer and the shorting
plate.
This is for an old SB-1000 Linear Amplifier, It also looks like some
one with very little skills in the field attempted repairs on their own
by looking at the other locations.
The owner of this unit really wants it correct and of course, the
parts are obsolete. It must of been a common problem because I find
hit after hit on the google from those looking for these switches.
So, I have some new ceramic switches here now that I will be drilling
out the rivets for the wipers etc..
This is the problem however, the wiper shorting plate also took a hit
and got burned, warped etc.
What I will be doing is drafting out a new plate on the PC, and
using a thick sheet of brass. I will laser print image at 1:1 and iron
it onto
the plate as a template.
Now because I will be doing this with a rotary tool in a vise and XY
table. I need to glue this plate to a piece of wood or phenolic material
to hold it in place while milling it out.. Of course, I'll need
to where my head magnifiers for this.
When I get done with the edge cutting, I need a way to remove this
plate from the block by softening or some how separating the plate
mildly with out bending it, do any of you know of a way that will soften
the glue? I was thinking of Acetone? But I am not sure about that one?
When done, I will be silver plating this. I also need to get some very
small screws and nuts like around #0-80 for example. I don't feel like
riveting it back together..
So, does my idea of doing this sound plausible if I can find an easy
way to remove the epoxy that will be holding the plate down during the
milling and edging process ?
Jamie
plate.
it onto
Jamie
