Kellys_eye and dorke. Thank you for your quick replies and helpful suggestions. You've certainly made me think. Perhaps I should have given more information in my original post.
My main interest is repairing and restoring equipment from the 60's - 90's, mainly test equipment and audio. So calibrating against a reasonably accurate reference is quite important for me. While I have lots of kit, I'm frustrated by finding that none of it ever seems to agree! So my thinking is that I should splash out on a good piece of kit e.g. the 34401A and use that as the reference for everything else (as dorke's suggestion). I can justify getting such a DMM by buying a tired / broken one and calibrating it.
Kellys_eye: I have in fact already done exactly as you suggested, and attached is a pic of my 5V standard based on a design by Skullcom on YouTube.
. It has out of the box accuracy quoted at 0.01% and can be further tuned externally. I have a set of resistors rated at 0.05% (cost me £3-4 each), so can produce a range of DC voltages and currents., Pic attached of the unit built into a business card box. I need to fit stouter wiring when I get a moment.
This works well to
confirm calibrations for low voltage DC but to follow the calibration procedure properly you need a range of voltages and resistances. For example, my Keithley 177 requires 19mV, 190mV, 1.9V, 19V, 190V and 1000V and that's just for DC voltage!
dorke: Understood that calibration is performed from the front panel, but I believe you still need an external calibrator to provide the reference. The Agilent manual suggest the Fluke 5700a or the Agilent 3458a, both of which are of course rather expensive. The self tests only confirm performance, not allow a recalibration if the unit has been repaired for example.
Thanks again, and do shout at me if I'm still missing anything
