JA
Hey Guys,
I have a couple of 4 month old 18V Ryobi cordless drill batteries that
were working fine with casual use in that they were charging and
discharging properly until one of them has decided not to charge up again.
What normally happens is that the battery would drain with use and then
you pop it into the charger and the red light on the charger would
signify that it was indeed flat and that the charging cycle has commenced.
Once the battery was fully recharged the green light then lights up on
the charger. This still works for one of the batteries but with the
other one, even though it's flat, shows a green light on the charger as
soon as you place it in and therefore the charging cycle does not commence.
Does anyone have an idea why this is happening and if anything can be
done about it? I have lost the receipt so Bunnings won't exchange the
battery. Even when a battery is at the end of it's life it would still
recharge but it would only provide a few minutes of use before going
flat again.
cheers.
p.s. I have tried the battery in one of Bunnings new chargers and it's
showing the same green light.
flat again.
cheers.
