I bought myself a desoldering gun so I would be able to recap old pc motherboards. Today I started practicing removing capacitors on some scrap pc motherboards. I managed to remove about dozen of them, but the holes in the motherboard are not very clean and it might be difficult to put new capacitors there.
Anyone has any advice on what is the best way to remove components from those multilayer pc motherboards. What kind of temperature I should use with the soldering gun and how long I should be holding the tip of the desoldering gun on the legs of the capacitors before I try to suck the solder out of the hole?
I will keep on practicing before I desolder anything on pc motherboards that I want to keep, but I would appreciate any help that would make the desoldering results cleaner.
