Joerg said:
Do you think SC-75 is here to stay? That would at least yield a
factor of two improvement over SOT23, roughly.
There are enough footprints in that size, and the cost is comparable.
I think it's here to stay. IMHO the SSS-mini is still wait-and-see,
perhaps the CSPs will supercede it.
Nice! Looks like a bit much in solder. Try Kester 15mil and a Weller
ETS tip.
Those were hand soldered with Kester 20mil, with a Metcal 20mil
conical tip. Since then I've gotten a syringe of paste, it works even
better than wire solder - dab a bit of paste on the pad, place part,
heat leads with iron, paste melts.
Plus a nice USB camera if there is one that can be fitted with a
zoom lens (macro is too close to the iron). I don't like microscopes
much and the 3x glasses in the lab aren't going to cut it anymore
for 0201.
Most of my close-ups are taken with an IntelPay QX3 microscope. The
bigger ones are taken with a digital camera; the Canon A70 has a macro
setting that works real well if you put a few layers of paper in front
of the flash to reduce the glare.
Other side:
http://www.delorie.com/pcb/smd-challenge/mine-front.jpg
Here are some other photos taken with the QX3:
http://www.delorie.com/pcb/smd-challenge/fp-pix/
As for actually soldering, I use a 3.75x mag visor (10 diopter) for
the 0201's and 01005's, and a 2.5x (5 diopter) for everything else. I
got them from Woodcraft (they're sold for scroll sawing, which I also
use them for).
I always wondered why they splintered up the descriptors so
badly.
I'm guessing it has to do with lead size, length, etc.
