Hi, I'm working on a project where I need to lift and lower hundreds of small pins. The best solution I could think of was to use small electric motors. Figured magnets would cause interference with each other and hydraulics wouldn't allow the same amount of control without a lot of calibration.
The issue is the smallest motors I can find are too big, and cost at least a dollar each, would add up way too fast. Does anyone have an idea for how to use one motor to control more than one pin? or know where you can find small motors for less than a dollar each? Any ideas are greatly appreciated.
The pins are going to be small, 2 mm diameter and 2-3 cm tall. The material isn't important and they all need to be moving independent of each other and ideally have different speeds that they move at. They don't need to be tightly packed either.
Thanks for reading, and for any help you can give
