Really need help!
I am building a rotating lure dryer and have got a motor a speed controller and a power supply but I cant get the motor to work with the speed controller. The motor works on a battery and the speed controller works on my power supply but they wont work together! I ordered a DC power supply and was sent an AC one. The speed controller is apparently DC according to the chinese ebay description lol and I have no idea what the motor is.
https://www.ebay.co.uk/itm/DC6-60V-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
https://www.ebay.co.uk/itm/12V-DC-5...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
those are the parts I got from ebay and they are wired as labelled on the speed controller. The power supply has an adapter that takes wires as in the ebay pictures.
bertus
Hello,
The power supply has AC input.
The power supply is 12 Volts DC on the output.
Connect the power supply this way to the controller:
Bertus
Obviously DC as it works from a battery.
Useless. You'll need a DC power supply rated at the same voltage as the motor (in the range 6 V ... 60 V for the controller to work).
How do you know? Definitely not if it is an AC supply as you mentioned elsewhere.
But the link points to a DC supply.
I'm confused :(.
Try the speed-controller with the battery to ensure the issue is not with the speed controller.
I'm confused :(.
The speed controller works on the battery. The power supply has AC written on it lol
Looks like.
This kind of power supply usually is DC, even te one you suspect being AC seems to be DC as the power controller "works".
The controller alone of the controller plus motor?
the motor will work on the battery and the controller will work on the battery but when you wire all 3 together only the speed controller will work. Do you think it could be a bad connection between the controller and the motor?
You keep repeating that the speed controller does work. How do you know? Did you measure at the motor output connection of the controller? Even if the display lights up and is controllable by the potentiometer, this does not necessarily mean that the controller works. The power transistors at the output may be defect, for example.
would the wire I used to link the controller to the power supply make a difference?
The wires you show in your picture are good enough
I'm out of my wits :(
One more thing to try: connect the motor and the lamp in parallel to the driver's output. Will the lamp still dim with the setting of the potentiometer?
I will try that now but could the motor be a higher voltage? would that cause it to not work? I didn't buy the motor, it is one I have had for a long time.
