W
Winfield Hill
Myauk wrote...
Drain-to-gate shorts is a typical failure mode for power mosfets.
Amusingly, the mosfet is still probably operating properly, that
is it's operating the same as any other mosfet with its drain and
gate externally connected together. But I digress.
You want to know why the part failed. SFAIK, any of the various
overstress conditions can cause this type of failure. E.g.,
overheating, in any of the ways Rds(on), switching losses,
avalanche heating, or overvoltage. Including gate overvoltage,
which can happen if a high current is switched too fast, causing
high dI/dt, and a substantial source-wiring inductance, causing
high V = L dI/dt, which can be a short damaging gate-voltage spike.
Lot's of handwaving there, but the standard remedies apply, a diode
across the coil, a gate resistor to slow down switching speed, etc.
In a typical PCBA design which consists of relay driver circuit, we
found the FET drain and gate short circuit problem causing damage to
MCU DIOs due to excessive sink current in production on 5 or 6 failed
out of 100 PCBA units.
2. Or is there any possible fault condition which can cause a good
working FET to have gate and drain shorted?
