Nemo
What is the approximate cost of pcb assembly relative to pcb
Lots of variables, but for a first finger-in-the-air estimate that's not
going to be far off.
In general for LARGE runs the assemblers consider how many components
there are to place, of how many different types. This determines how
much time / how many different types of reel will be needed.
But for small runs other items dominate the cost. Apart from component
prices, you need to consider if the components are available in these
quantities (that's tripped me up recently - I spec'd something only
available in quantities of 250 or more); how many different suppliers
the assembler will need to deal with, because that will take a lot of
time; whether there are any special operations like, mounting components
on the underside of a board.
I recently used a tiny (1 man!) assembler in the UK who used a
semi-automatic SM assembly machine. It was very impressive, placing
things under manual control but doing the fiddly work for him. Good
blend of machine and man for small scale stuff. Many assembly houses are
either purely manual or purely large-scale automatic SM machines, with
all the setup hassle their overheads imply.
fabrication for low quantities? If I have 50 boards ordered at about
30$ each for pcb fab can I expect about a 1:1 cost for assembly?
