RCA,PTK195,CTC195 Audio resistor value needed
K
Karl Kvicala
Hello,
Working On an RCA PTK195 chassis with no audio.Found open R14153
resistoron the secondary side of the power supply, but not sure what
it is. It may be a 10 Ohm but it is burned and discolored.
It powers the B+ for the audio amp.
Let me know.
Thanks,
Karl K
Karl Kvicala said:
Hello,
Let me know.
Thanks,
Karl K
The official PTK195 chassis parts data base shows the following information
for R14153:
Symbol Stock Description Circuit Model Version TypeCode Drawing Notes
R14153 241551 RES MF 1W 5% 470R CHASSIS NSM TL_T A XX90572-180
I would say that its 470 ohms.
Greg S.
Art
Be advised, Per TTT 00-001 Bulletin
No Audio in Tuner Mode, Line inputs not affected
Check U16201 #49 should be Apx 3.9 VDC, not functional will check Apx 7 VDC
CTC-195-197 C-12304 possibly open - Pin # 3 of L12303 (NEAR Pin # 1 of
U16201)
Also Check diode CR12301 - Pin # 1 of L12303
Aggrivating problem but a sure fix, per Thomson.
